Results 1 to 8 of 8
    Mar 2004
    Default Newbe needs info on board size
    Hey just got a new SSV Launch and now need to get the goodies!!
    I used to wake board 7 years ago then got out of it. Now I am older and well, heavier..
    (37 & 220lbs) I have looked at boards but it really has changed since I was on the water. I just want to crusie and get smooth air. Anybody got and insight besides loosing weight. Thanks!
    Default Replying to Topic 'Newbe needs info on board size'
    I'm 54 and 220; Worry about good bindings and get a used board. Kids upgrade all the time just for the graphics. For a rider like me two fins three fins molded fins don't matter.
    Sep 2003
    Atlanta, GA
    Visit Hyperlite.com. They used to have good board selection guidelines with a chart.
    2002 SSV Owner
    For that weight, go with a 140 or 142 board size. Most new boards are going to be fine for you as long as you go with the correct size. Visit the manufacturer's web site to find out what model they recommend for the most pop off of the wake. With a board that provides good pop off of the wake and is size 142, you can't go wrong for with any brand for doing what you want to do.
    Good luck.
    2004 Launch SSV Gravity Games
    Jun 2004
    I would suggest riding a 142 something with surface area and floatation for you. I ride a belmont 140 and its awsome... Check out hyperlite.com...any more questions just ask...
    May 2004
    I would suggest at least a 142cm board. The bigger the board the softer the landings are and the easier it is to carry speed into the wake (and not sink yourself). Height also has a little bit to do with what board size you use. The best thing to do is get out and demo a few before you buy anything. Some of the new boards feel alot different than boards did seven years ago.
    Sep 2003
    Atlanta, GA
    I have a 2000 Byerly 142 for sale. if you're interested, drop me a PM.
    - Jim
    2002 SSV Owner
    Mar 2004
    Arizona
    We jsut opened a new board shop on-line (TheWakeStore.com), and I would suggest a board with a 3-stage rocker or a 3-stage continuous rocker to help get a nice transition up and off the massive wake that the SSV puts out.
    A board that would definately meet your need is the Blindside Blade 142. It has a smooth 3 stage rocker that will totally get you up in the air and it is really loose feeling. I suggest this board, because it is what I am riding, and I love it! Plus it is a lot cheaper than the bigger name boards with the same rocker line! Save the dough!
    Nate
    2004 SSV (Fully loaded)
    www.thewakestore.com
