Ok guys. I need some help.
I have an 04 SS launch with the 2 ballasts system. 1 hard tank in the back and 1 bag in the front. The front bag will start to fill when boat is in motion. The back ballast doesn't fill. Only the front. It will continue to fill until it overflows into the boat. The pump is not functioning while connected to the boat. I pulled it out to check it and it works fine but for some reason it is not getting power when connected to the boat. Could this be the cause of the constant filling? I had to shut the valve off to avoid nose diving due to the boat riding so low.
Any ideas out there?
