Originally Posted by
dshaff24
I don't know if the newer style boats do this but my 86 sunsport pulling a tube behind the boat from the rear hook creats the tube to be pulled nose down in to the water and snaps the line so last year we been pulling the tube from the pylon with out any issues and it makes tubing a blast compared to being pulled behind my speedboat, Now is the pylon rated to be pulling a tube? How about a wakeboard tower? Reason I ask is because when we have friends and fam down the tube is the #1 water sport and I want to actaully remove the pylon for more room and maybe use the tower, The tube is a small 1 person really, but 2 can fit with limited room!
Just looking for some input, My tower is a fat bar2.25 side bars and 2.38 top bars
How is your pylon mounted? On the newer V-drive boats it is no problems with towing a tube on the pylon. If it is the old style with a longer pole and not too much support I would probably not recommend it. Definitely a "no" on towing tubes with your tower --- wakeboards only on the tower.
Do you have some pics on how your pylon is mounted?
Just my .02
White/Charcoal, 2011 VLX
2008 Supra 22SSV
