Results 1 to 6 of 6
Thread: Alignment
    Mar 2004
    Lake Tahoe
    Default Alignment
    When doing an alignment check, is it proper to just hold the flanges together firmly by hand when checking with the feeler guage?
    Mar 2004
    Default Replying to Topic 'Alignment'
    no, bolt the shaft coupler to the tranny first
    Mar 2004
    Lake Tahoe
    flyinj,
    If I bolt them together, I can wipe out 0.001" gaps with barly a turn of the nut. How precise is this operation anyway?
    Nov 2003
    Houston
    I just pulled the shaft on my boat and have the same question...Is aligning the shaft just a matter of bolting the coupler to the tranny evenly? Am I a rookie or what? I'm not even sure what a feeler gage is! I'll be calling Vince at Skidim tomorrow...
    Mullet-free since 93
    Guest
    I just went through this issue with Vince last summer and it was my understanding that you do not bolt them together to make the measurement. You put them up to each other and take measurements all the way around the plate. And the tolerance is quite small. The feeler guage will seem almost paper thin for the measurement. I also had someone run the boat while I put my hand on the transmission to feel for vibrations just as a double check. I have no idea if this trick is helpful as a doule check or simply a placebo.
    May 2004
    You know, I am certainly no expert but Brian at skier's choice was kind enough to e-mail me a pretty good procedure for checking alignment. According to this procedure, you have to remove the four bolts that connect the couplers. Then check while holding them together. If you call or e-mail, they will send you the procedure.
