Results 1 to 3 of 3
    Jun 2002
    Michigan
    Default 454 sucking gas??
    I was looking at a boat the other day that had a 454 in it. I can't believe this is even a question, but w/ the way gas prices are going, it is a concern now. I bet gas on the H2O this year will be over $3 a gallon. How are the 454's on gas? I would say my time is spent 60% towing/40% putting around. Any info helps! THANKS!
    SuckMyWake
    May 2002
    Muncie, IN
    Default Replying to Topic '454 sucking gas??'
    Big Blocks need big gas tanks. There is one exception. If you pro weight a wakeboard boat you might actually do better or at least even with a big block. The key here is having the touque to keep the rpm' s down. But watch out when you blow the ballast and cuise down the lake and pull slalom skiers or barefooters requiring high rpms - you will pay.
    Chris Walker
    President, www.spotlessboat.com
    President Emeritus, www.usawakeboard.com
    Nov 2003
    Houston
    my 454 loves gas. Keep the engine well tuned...you know the basics, but generally the bigger the engine, the more gas.
    Mullet-free since 93
