Mapleleaf,
Typically a continuous rocker will be found on more of the advanced boards which will give more control but a little less pop off the wake. The three stage rocker tends to be found on the more beginner/intermediate boards which gives you a better pop but with less control. There is also the Hybrid rocker that tends to be in the middle of the pack. You should really ride different boards with different rockers to find what works best for your style. Personally, I like boards that track well and cut easily, I just picked up a CWB 142 Transcend Platnum which is rated Advanced, with a continuous rocker and full spine. I can hardly wait to get out and ride this spring!
My kids ride a 134 HL Motive and they love that board, it gives them good control and a nice pop off the wake.
For softer landings you need board with a full spine down the middle from tip to tip, this will help displace water when landing. The larger your board gets the softer your landings will be. Bigger boards will not be as easy to spin and control.
Clear as mud?
White/Charcoal, 2011 VLX
2008 Supra 22SSV
