351 Ford Engine in 89 Supra
I changed the oil and filter on my boat today. When running the boat using my garden hose for cooling, I noticed that the prop was turning. Of course the boat was not in gear and I double checked the throttle just to make sure. Is this common in this boat for the prop to turn some when in the idle position out of the water. Please advise, this is my first summer with this boat.
Replying to Topic '351 Ford Engine in 89 Supra'
not a problem just a nice tight transmission, the clutch pack is tight . with no resistance out of the water the prop turns on a lot of boats
