I first started by taking the cap off of the factory oil drain hose. I took it to the local hardware store to find correct fittings. The fitting consisted of the following. (sorry if I dont have the corrent name for all)
(2) 1/2 to 3/8 reducer
(2) 3/8 to barb
(1) 1/2 ball valve.
(4) hose clamps
(1) left over speaker wire
(1) inline fuse holder with 10 amp fuse
(1) package of positive and negative clamps
I found the smallest ball valve they carried. This is used to make sure that pressure dosnt force oil through the pump into your engine compartment. At first I had it plumbed strait into the pump. I called a friend of mine and he said that I should probably install the valve.
The hose is a 3/8 id fuel hose. I think that I bought about 10-12 ft. I had a little left over.
08 24ssv Gravity Games
1200, 1100, and 750 Fly High Bags
6 Optima Blue Tops
Guest 10 Amp Charger
WS420
6 WetSounds Pro80s 10 xs650s
3 zx850.4 1 zx550.2 1 zx1000.1
Oil Drain Pump
I then went to a local farm and ranch store (Attwoods). I located the portable sprayers (units on wheels for use behind tractors / movwers). They carried all differnt sizes, volume rates, and prices. Flow rate was not an issue for me. The pump I chose was the cheapest. It came with 3/8s barbs on both intake and exhaust side. Another reason that I chose it. I believe the pump was about 65 dollars. The pump included hardware to mount.
I mounted the pump on the inside of the engine compartment (photo shows pannel from inside the storage locker). I had to loop the intake hose arround to the transom side of the pump for proper flow.
The exhaust hose was left long enough to reach to the swim platform. I installed a 3/8 to barb on the end of the exhaust hose. I then installed the factory hose end to the fitting to cap it off.
I used some left over speaker wire for power and ground. I used small jumper cable clamps for connections. I thought about jooking the pump up to the aux switch on the dash but decided against it. I didnt want anybody turning it on and burning it up.
I am by no means a professional. This is just me tinkering arround trying to make my life easier. I had a portable oil pump loose its connection and spray oil over me and the back of my boat ( 10 hours new). I swore that there had to be a better way and this is what I came up with. Any questions? Just shoot and Ill try to answer.
6 Optima Blue Tops
WS420
Oil Drain Pump
Could you post up the name of the pump/model # you used?
That is pretty awesome. I have had the hose come loose on me once I got oil everywhere as well. Its a pain in the butt! I also might try something like this in the future. This would fall under one of our $100 mods probably
Good job and GREAT writeup!!! Thanks very much for your contribution! FYI you can use code to make the line in your signature into a link to take people right to this thread.
Code to put in your sig (remove the spaces at beginning and end):
Viton: (recommended for use with petroleum products)
Viton® oil seals feature excellent resistance to petroleum products and solvents. They have good high temperature and low compression set characteristics. They are suited for use with wide chemical exposure situations and for hard vacuum service.
^Assuming those links confirm the engine oil will not harm the pump components?
On another note, I randomly got a northerntool cataloge in the mail today and they have this pump for $39.99. Same specs, manufacturer is northstar. I believe I will order it and swing by autozone and lowes to get the other few pieces. I will most likely leave the wiring independent from the boat and use small clamps as well to just jump to the battery when I need an oil change, this way there will never be a chance if accidently powering it. I'm assuming the existing oil drain hose is 3/8s and will hook directly to the suction side of the pump, or did you have to remove it and lengthen? I've never even looked for it.
2006 Supra 20 - Sold
2006 Supra 24 Gravity Games - Sold
2015 Supra SE450 - Sold
