Here is my new (to the boat) altinator. It is a lestek model 9135 DG. It is a dual 135 amp out.
08 24ssv Gravity Games
1200, 1100, and 750 Fly High Bags
6 Optima Blue Tops
Guest 10 Amp Charger
WS420
6 WetSounds Pro80s 10 xs650s
3 zx850.4 1 zx550.2 1 zx1000.1
Oil Drain Pump
What happened to your old one? I would think with an '08 you would not be having any problems with it.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
if he has a 325 hp engine it only has a 70 amp alternator......may want more to help keep the stereo batts charged and keep the wetsounds pimpin
2009 21v Worlds 340 Cat
Doug
135 AMP should be plenty! I have never had any problems with my 90 charging my system, but then again I only have 2 amps.
2008 Supra 22SSV
It is a 270 amp. I had it powering this...
6 Optima Blue Tops
WS420
Oil Drain Pump
No problems with it. I just had this sitting arround in the garage collecting dust. Im about to add a 3rd and possibly a 4th amp.
6 Optima Blue Tops
WS420
Oil Drain Pump
