Systems Monitor on 94 TS6M
I recently purchased a used 94 TS6M. While under the dash replacing a gage light, I noticed a multi-pin plug (maybe 12 wires) that was not connected to anything. The wires match the colors on the wiring diagram for the Systems Monitor. Where is the Systems Monitor mounted and what is its approx size? Is the function of the Systems Monitor is to act as an early warning system? Also, the fuses on the fuse panel are not labelled. Does anyone know if they are marked anywhere or do I just have to pull each one out to find out what it does?
1994 Supra TS6M
