Does anyone know if the gravity games ballast from a 24 ssv will fit in my 2003 22 ssv? I have to replace the stock center sac and am toying with the idea of just upgrading all of the sacs.
2003 Supra Launch 22SSV
Upgrading all the ballast is a great idea. . I wouldn't worry about the gravity setup, though. Pick up the 750 or 1100 fly highs. Do you have playpen or walkthru bow? That would determine your front sac.
It might sound like alot of weight but you will want it for surfing. I'll leave the fitting for someone with a 22 but you should be fine, just may not fill completely.
One last thing, do you have the quick connect fitting on your hoses?
Hey KG... Thanks for the response. I have the walk thru bow and yes, I believe I have the quick connects.
The fly highs are a quick swap out. I'd call a dealer when you order to make sure you get the right fittings. Alot of people here would recommend wakemakers. My experience, they all sell the same product for the same price.
Either the 750s or 1100s would work great in the back. Could get away with just getting one for surf if your not worried about them matching. I'll leave the center/bow bag to someone else. I'm only familiar with playpen. I'm not sure how big you can go up there.
Saltare - Yes, if i upgrade i'll sell the 275's in the back.
KG- Thanks again for the response. The guy says they're 600's in the back and 1250 center. Looks like they have the quick connect setup.
ARe you reffering to the gravity games setup? That sounds about right. I thought the bow was 1150 but I haven't looked in a while.
Compare the price on the 600's and the 750's. When I looked the 750's were a no brainer. Don't get too focused on the gravity setup bc it will need to be upgraded for a good surf. I add weight to my 750 and wish I had the 1100.
I am unsure whether or not that 1250 sac will fit in your bow without playpen.
I'm sure someone else will chime in and help out ...
My advice is to just leave the drain plug out and back the good old 22 in to lake mead, i would also just let the boat take the avalanche with it. You will be better off. Then you can go get that green 2010 21v at the supra dealer!!!
