Can anyone give me some info on changing from points to an elctronic ignition in a 90 conbrio.
Piece of cake. Get yourself a kit from skidim - call to make sure you get the right one, then just follow the instructions. I did mine, cost about $150 and took an hour. Big improvement and worth the $$.
When you say big improvment, What changed?
Check on Summit.com. Should be about 90 bucks. Again, make sure you get the right one. Pertronix makes several specifically for marine applications.
No more points to adjust or wear out, hotter spark, fewer misfires, the distributor stays cleaner, etc. I have yet to find a down side... And very easy to install in your driveway without pulling the distributor. Oh, and there is less fouling of your plugs because of the hotter spark. And it usually starts easier. Did I forget anything? I put mine in several years ago and have only pulled my cap to look in at the beginning of the year to make sure everything is still under there before I fire it up for the season; other than that, I pretty much forget about the distributor...
Wonder which one my 1989 454 would take ?
Skididm will know exactly. They are extremely helpfull there. I asked them all kinds of weird questions and the never skip a beat then give a simple answer.
I wonder if this is what I need -- I have a DEI electronic ignition on mine but I don't think it's a marine ignition. Seems like the contacts in the distributor get corroded once or twice a year and need to be replaced. Will a marine setup fix this?
Wotan I have been having issues with mine ever since I got my boat, I am replacing completly this spring.
I HAD elec ignit, but (long story - couple magnets fell out and hasnt worked the same since. Also not getting correct spark from two plugs) now I have points again (down time is unnaceptable!). They actually run okay, but we have some motor maitanence this spring that I am not really looking forward to lol!
We rebuilt the carb last summer, it seems to be doing pretty good but could still use some fine tuning by a pro...
Also gotta do throttle cable, possibly steering cable, possibly exhaust manifold gaskets, possibly valve cover gaskets (some kind of blowback noise, cant tell exactly where yet), the elec ignit, ... i think that's it
