Originally Posted by
JoHNI_T
I picked up a 2006 22SSV 2 months ago, I had my local dealer run it up to temp and confirm everything was ok, it checked out fine.
I took the boat for a 30 minute run over a week ago and last night I noticed when going over the boat the v drive oil is milky??
any idea's, no obvious cracks or leaks and the oil level is normal so its not much water in there?
my dealer says the only way to check it out is to pull v drive and crack it open???
this suks, we just got warm weather. and it wont be cheap to pull this v drive.
The most common way to get water in a Walter V-drive is a leak at the gasket that is under the cover that the oil dipstick goes through. Under that cover is a water chamber and sometimes we see water from the water chamber run down the dipstick hole and into the v-drive. The external trans cooler that is in the 1 1/4" water inlet line and located between the raw water pump and thermostat housing only cools the shifting transmission. Generally a leak in that cooler puts trans oil into the cooling water and not water in the oil because the oil pressure of the trans oil is higher than the water pressure. I would carefully remove the cover and put a little sealant around the dipstick hole in the v-drive and the water chamber cover.
Larry Engelbert
Indmar Marine Engines
