If my wife is driving I can always count on water coming over the bow, especially when surfing.... you should have a front/rear bilge pump which will help get rid of the water quickly. On a hot summer day its gone in no time, but I do think the Supras front end is a little lower than some other boats. It also depends on how much ballast you are using the bow area.
These boats are also WAY overloaded when the ballast is full, I believe my 22V has a weight limit of 2,100 lbs (might even be less), I have 1900 lbs of ballast when everything is full, thats probably double the amount of weight that is supposed to have in it. I still cant figure out how they get away with selling them with a weight limit sticker when loaded up with ballast far exceed the max limit.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
