Does anyone know how to remove the floorboards in a 07 launch 24ssv?
Good question as I'm trying to remove one today to get to the ballast wiring.
So the floor boards have Phillips screws located in the corners kind of hidden under the wonderful carpet that gets nasty after two season. Find the seam for each set of floor boards and in the corner you'll see the screws. Will require some digging. You'll probably have to remove the large bench seat as well and the support for it if you want to get the floor boards up. Any coolers will also have to come out. I recommend using a power drill with a torque setting because some of those screws are long as hell.
