How do you get the back seats out? Center seat is supposed to pop out according to the manual. It does not. Cannot see what it might be connected to.
SEATS
REAR
to get the rear seats out, you have to remove the middle half-seat first. it creates pressure on the outer seats keeping them locked in position.
to do this, check under the middle seat cushion to see if it is screwed to the floor. i'm pretty sure mine was, i don't screw it down anymore as it's not necessary. either way, you'll have to get the middle section out. it doesn't really pop out if a manual is telling you that.
it's easier said than done, the carpet wrapping will grab creating friction even after the screws are out. you'll have to wrestle it a bit.
once the middle piece is out, the larger side sections come next. but, there are screws in the floor and there are bolts in the sides that fit into holes in the hull. so, you'll have to angle them out once the brackets on the floor are removed.
write back if you have trouble
