Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: How to ollie
    Nov 2009
    Houston, TX
    Default How to ollie
    This is my first boat, and I coming up on the 1 year mark. Finally got some good time spent on it in the last 2 months. I finally feel comfortable to start trying things (tricks). Landing some 180's over the wake, just landed some 180's out of the wake this weekend. My biggest problem now is riding switch.
    So here's the deal
    1. Any one got some good tips to learn how to ollie.
    2. Any one got good tips about fighting the awkwardness of riding switch.
    3. Any other good tips are also invited.
    88 Supra Comp ts6m
    Dec 2009
    McKinney Texas
    Hey DB
    Did you try going to the trick room link at the top of this site? Good info in there.
    2004 Supra Launch SS
    Feb 2009
    Missouri
    Yea you want to ollie by putting pressure on back leg and lifting front leg up. Then quickly lift back leg up to pop yourself in the air. Its just like a bunny hop on a bycycle.
    Nov 2009
    Houston, TX
    yeah. I watched the basic learnig with the ollie heelside backside 180. Everything else is out of my league at the moment.
    88 Supra Comp ts6m
    Jun 2010
    Ontario, Canada
    As for the switch thing, there's only one tip...practice, period. The more you do it, the more comfortable you will get, there's no trick to it.
    As for ollieing, i assume you're talking about in the flats. The idea it to pressure down with your back leg to create a small wake and pop off it. Not horribly difficult, but takes some practice to get dialed in.
    good luck!!!
    Feb 2009
    Minneapolis, MN
    start with small bunny hops and then try to increase your height later. Don't try to 'jump'. Instead think like you're on a trampoline. You have to bounce down and the water will pop you up. The water ollie has a natural rythem to the stomp part so start small and learn the timing of the bounceback.
    Once you're going beyond the small bounce, bend your knees deeper and push off your back leg a little harder. Suck your knees up to your chest and throw your trailing arm out for style. Keep the tip up if you're bonking stuff, this way if you dont quite get the height you will not catch your tip.
    Nov 2009
    Houston, TX
    thanks guy's. I thought i was doing pretty good until i landed the 180 and can't ride switch. I'm 10 times better than i was that day, but it;s like starting all over again. We'll see if i can't figure out this ollie thing next time at the lake.
    88 Supra Comp ts6m
    Sep 2009
    Western PA
    I started doing surface 180's. I pull hard on the line so that it gets slack, then spin the board around. (I ride left foot forward, so when riding switch, I hold the handle with my right hand only to straighten the board out after rotating). I find it more stable bending my knees more and settling it down. Riding switch more often will build comfortability. Now, I don't need the slack in the rope to switch the board after 5 times of doing it.
    2004 Supra Launch 22 SSV
    5.7L Indmar Assault
    "One More Hour"
    Mar 2009
    Roseville, CA
    For the orbital flushes you will be encountering when catching an edge , a helmet has been a huge help for me. Not so much for faceplants, but hitting your head at 22.4 MPH on the water can actually give you a good headache.
    Also, when you are spinning the board on the water if you slow down a little for practicing it makes the falls a little easier on the body. Hmmm.... I must be getting older!
    Just my .02.....
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
    Feb 2009
    Missouri
    I just skip all surface 180s. Its is easier(for me) to just jump the wake and spin or ollie and spin. Thats how I teach also. That fall seems softer because of the time you have to prep for hard fall. When falling during surface 180 you have little to no time before your head is hitting the water. Side note, when you fall on any trick blow water out your nose as you hit the water. If front fall put arms in front of face to deaden the blow and when back fall spread out like a jumping jack. That spreads impact through whole body. These tricks have immensely reduced pain from hard falls. No Pain, No Gain.
