Was servicing engine, tranny, while hooked up to the garden hose. When I shift into gear at idle there is a terrible racket that appears to be coming from underneath the boat. Since there is nothing under there except the shaft and the bracket that holds the shaft it must be the bracket, but I can't find anywhere to lube that bracket.
Does this disappear when in the water or am I missing something that needs grease?
Thanks,
