air chair
Anyone ride an air chair on here.
88 Supra Comp ts6m
Dickboxers,
I bought a sky ski a month ago and we are still trying to figure it out. There are a couple of things to do that will help you get up if you are a beginner which I still am. We took the 75' ski rope and shortend it by about 30' which really helps. Also ended up taking the front foil off for this is what causes the lift and it really helps learning to get up and out of the water and helps keep the ski on the water. I can now get up everytime. This also gives you the opportunity to learn how to steer the foil. We are still at this stage at this point but I love it and am totally hooked on it. You can also tie a piece of rope at the bottom of the t-strut down at the very bottom this helps prevent lift as well but did not work as good as taking the front foil off. Keep me updated on your progress.
