Ballast Switch Miswired?
When my ballast switch is in the middle (off) the ballist fills up. When the switch is up (fill), it also fills. When the switch is down (drain) it drains.
So you can see my prob. THeres no neutral
is ther any ring or anything that can close off the pipe access to the ballast to prevent them from unexplectedly filling?
Or do I need to get them rewired? Whats the problem?
