Results 1 to 5 of 5
    Mar 2010
    Western ok
    Default Tsunami 800 drain
    I'm putting one of my 800 pumps on my drains, the factory port rear pump went out... Anyway can you screw the 3/4" end off of the tsunami directly into the bag? I know it fits but will it seal?
    Sep 2009
    Western PA
    You can put plumbers tape around the threads.
    2004 Supra Launch 22 SSV
    5.7L Indmar Assault
    "One More Hour"
    Aug 2008
    Ontario
    Quote Originally Posted by jzelt View Post
    Ditto to the teflon tape, you could use pipe dope, but its hella messy.....
    90 Conbrio
    Mar 2009
    Roseville, CA
    Quote Originally Posted by Matt Laird View Post
    Yes, you can screw directly into the bag, however, might want to consider a different setup that will allow you to disconnect the bags from the pump easily when removing the bags. Plus, I think it will actually lay much nicer in the compartment sideways.
    Just a thought....
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
    Jun 2009
    Northwest
    Don't bother with the teflon tape, because the flange on the bag is pliable, it won't seal correctly against the inlet of the pump.
    Travis, he did ultimately go with our drain pump quick connect adapter, but UPS isn't delivering the package until Thursday.
