Results 1 to 4 of 4
    Default help me shape my wake
    i have a 02 supra dd i have a 440 pound sofa sac on the left side of the engine 300 across the back in the ski locker and the stock tank under rear seat which is 250 i think... and usually a 250 dude sitting in the left rear... my wake is thigh high and super steep but kinda short and soft like i need MORE volume does anyone have any tips please? i can surf it very well i just want to be further back to do aerials and 360's
    May 2009
    Sorry, I don't have dd experience, but, in general, if you need more length to your wave then you should add front weight. It doesn't sound like you have a bunch of rear weight, so try not to steal from the rear to supplement the bow weigth. I'm not reading any forward weight with your setup?
    I'd add another 500 to the walk-through or bow area(s), and another 3-400 to the surf side rear corner, to start. What's your speed?
    I run around 9 mph I just got another sac that's around 600 pounds i plan adding to the bow
    Aug 2009
    Plano, TX
    Speed up. You should be at ten to eleven MPH. It'll lengthen the pocket.
