Replying to Topic 'Soft floor'
The floor feels soft because when you put weight on it, it deflects. It should not do this. Good chance it is rotting from below. As for the stringers, I have also heard about the bolt test and it makes sense except that it only tests the area around where the engine is mounted. The stringers extend the length of the boat. Unfortunately, the only way to investigate is to remove the floor. I had my floor replaced professionally in '03 and they said the stringers looked as good as new...hopefully the same can be said for yours.
2005 Supra 21V
1990 Supra Sunsport Classic SOLD
