Decal Removal
What is the best (easiest) way to remove old decals and pinstripes? I have tried using a razor blade, but I did put a few light scratchs in the hull. The cement that holds the old decals and pinstripes on is tough to remove. I have an '87 Sunsport and want to wax the hull and place new decals on. Thanks.
Replying to Topic 'Decal Removal'
A hair dryer works fine, a heat gun is better but a little more dangerous. Acetone will remove any stubborn parts. Post some pictures when you're done
