Motor Specs for '89 454
I've just purchased an '89 Saltare with a 454 -- anyone know where I should set the timing, dwell, idle RPM, etc, etc -- need all the engine specs.
Thanks,
JCS3845
Replying to Topic 'Motor Specs for '89 454'
the only thing you may need to adjust is the idle speed which should be neutral 550 rpm. my advice is to not tinker with anythig else, that vintage 454 runs forever without adjustment or tune up.
Contact Vince, at Discount Inboard Marine, he is the Guru of older model specs. He also has OEM parts for older PCM and Indmar motors, he also supplies other replacement parts from fuel filters to steering cables. He can be contacted by phone @(803)745-0096, or check thier website out at; www.skidim.com. Tell him I sent ya. Hope this helps. Brian Raymond
