Results 1 to 6 of 6
    Default Another depth finder question, puck location
    Was wondering peoples opinions on this, I have a 94 sunsport. I was reading the manual and it says in the rear like near where the prop is, I was wondering if it should go somewhere near the bilge or someplace completely different the either of those???
    thanks
    1994 Supra Sunsport
    Aug 2010
    NJ
    I am wondering the same thing but for an '89 Saltare. I installed a gauge in the dash this week and just need to figure out a location for the transducer. I'm thinking either opposite the water pickup for the engine or near/under driveshaft/trans. Trying to think either flattest spot and spot with least chance of air or turbulance while on plane.
    Sep 2004
    Hudson, WI
    I can tell you where not to put it. I put mine in front of the engine right near the bilge pumps. It's never worked. I really do need to knock it out and move it somewhere else.... I think opposite the raw-water intake is probably the best place.
    96Comp Guest
    Default Puck Location
    Agree with WOTAN2525: don't put in front of the engine in the bulge. I relocated mine to the back across and maybe back of the raw water intake. Works well now. Picks up 95 percent of the time. Before - maybe read depth about 30 percent of the time.
    Feb 2009
    Edmond, OK
    Across from the water intake or somewhere in that range. That is a section of the boat that is in the water all the time. Stay in front of the prop so prop wash doesn't impact the readings, as well.
    Sep 2008
    Parkersburg, WV
    Yep - you guys are right. Jim installed mine just about opposite the raw water intake and it works really well there.
    Clint
    www.waketheworldwv.com
