97' comp classic
I have put new plugs in at correct gap. Also replaced cap and rotor. Checked all plug wires and they seem to getting spark at the cap and at the plug. Still have a problem with#6 plug. It's totally black but dry. Also, #7 and #8 plugs are very wet with fuel. I've been told numerous things. Everything from "the timing is off." To "you're carb needs rebuilt." And quite a few other things in between. It has a Holley 4160 600cfm carb. The engine has 293hrs. on it. And right now top speed is only 35mph. All help is greatly appreciated.
Supra 97
