Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    May 2009
    Peachtree City, GA
    Default Steering Cable block
    This is the block that holds the outside still while the inside moves. The angle that is held down by the strut bolts was loose. I tightened it up. The bolt that holds this block to the angle seemed loose. It would not tighten. I put a wrench on both sides and it was tight. The block is still loose. Is it supposed to be?
    Hopefully, there is a picture here.
    Thanks, David
    '99 Santera
    Aug 2008
    Ontario
    Most likely the inside of the clamp block is worn, and needs to be replaced.
    Ski Dim has them, cleaned up some slop in my steering when I replaced mine this summer....
    90 Conbrio
    May 2009
    Peachtree City, GA
    I found it. Thanks for the help, I'll order tomorrow!
    Aug 2009
    London, Ontario, Canada
    maybe the bolt is bottomed out and if you take it apart and add a washer it might be fine, or the bolt rusted in it?
    2009 21v Worlds 340 Cat
    Doug
    Sep 2008
    I ran into this same problem and we are not alone.
    So many people have vibration in the steering wheel on take-off due this problem.
    One guy on the Moomba forums added a teflon washer to take up the slack and his vibrations we solved. I am gonna give it a try this week.
    Aug 2010
    NJ
    My saltare has slip in this block, just needs to be replaced. Minelooks a little different IIRC, but same idea. There's a ball pivot in there that's just worn and has excessive clearance. It's on my winter project list.
    Sep 2004
    Hudson, WI
    Hmm..... my boat doesn't have this at all???
    Aug 2008
    Ontario
    I think it must be the cold water.....check again...LOL
    90 Conbrio
    Sep 2004
    Hudson, WI
    Hah! I'll double-check next time the cover comes off.... but... I've replaced the steering cable, helm, and rudder -- and I don't recall ever seeing that piece.
    Aug 2009
    hi all again, while winterizing my 09 i checked this and found there to be some play in mine as well...... maybe there is suppose to be some play? or is this suppose to be rock solid? I found them at great lakes skipper for $49
    Doug
