Originally Posted by
SECBENGAL
Hi all,
Well, I just traded in my Four Winns H200 and bought a 2010 Launch 21V. It has the stock 650 front and 400 rear ballast system. I know there has been a lot threads discussing wake setup on this forum, but most have either been for surfing or to make the wake more mello. My question is, what things should I consider if I want to make the wake as steep as possible?
More weight in the rear, less weight up front? Also, if I want a steep wake, is setting the wake plate down or up the best option?
If you put the wakeplate all the way up will get you a steeper wake lip, the more it goes down, the flatter the wake will be. You can create a larger wake by upgrading to the 1100 lb front sac, and 750 lb rear sacs. I am pretty sure there are some 21V owners that are using the 1100 in the front ski locker, and the 750's in the rear lockers.
Only modification necessary with the larger bags might be a longer fill line because of the added height to the bag. Some of the Supras dont need this, mine had to be extended. You will also need to reprogram your VISION.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
