Wakeplate housing
Any help in accessing the housing on the hyd-res for the wakeplate. It is under the rear seat and can be seen through the rear access at the engine compartment. However, it has a perm-holder and does not have enough room to slide out the top. And one last problem, with the ballast, the rear seat can't be moved.
The fixture that the unit sits in has two small brackets that act to secure the unit in the fixture. If they're like mine, each bracket is secured with a small screw and when loosened should allow the unit to lift out and pivot toward you to clear the seat and fixture.
