Results 1 to 4 of 4
Thread: Ice cooler
    Jul 2002
    Carrollton, TX
    Default Ice cooler
    I have a 200 Launch that I LOVE!!!!! But we used the built-in cooler for the first time and it drains out right out onto the carpet. Does anyone else have this problem and is there a fix for it??? Thanks!
    JT
    Jul 2002
    Carrollton, TX
    Default Sorry, I meant 2000....
    Duh...
    JT
    Jul 2002
    Atlanta
    Default Me too
    I have owned both a 2000 and 2001 Launch and both boats have had that same drain problem. I have been unable to find where the leak is coming from. I did notice that the glass around the drain plug in the cooler did seem thin and added a little extra silicone around the fitting.
    Jul 2002
    Memphis
    Default Cooler problem
    I have a 2001 Launch and everyone has the same problem. Bad design. The cooler drains into the area with the battery. You will also get the "sweat" effect with cooler to the front of the seat. It will stain the carpet so be careful. I have sealed up my drain, drilled another hole and ran a tube into the bilge area. I then coated the cooler area with the rubber compound that you coat tools with. Created a cooler that works.
