Originally Posted by
Sluggo
Doc, please share any information you might have as I plan to do my install this week as well.
As I was messing with things and trying to identify all the cables I was going to need and I realized that my currrent setup utilizes both front and rear of the head unit into the first amp (4 cabin speakers), then lines out of the first amp to the second amp which drives the factory Roswell tower cans (4) and the sub. Not being a stereo guy, I plan to put just one set of left and right into the HSE and then to the Clarion EQ. The EQ then has front and rear outputs so I will need to get rid of my lineout from one amp to the other so the fader will control the volume of the towers seperately. But what about the sub? There are seperate outputs on the EQ for the sub but not a seperate input on the amp, at least not in the current setup. With the KAC-8004 I could take the sub input from the EQ and connect it to the B channel on the 2nd amp to keep it seperate. Would I bridge that connection? I don't think it is right now, but I could be wrong as it is a little hard to get to and trace wires down.
