Replying to Topic 'Ultra Marine Mufflers???'
kchookie,
Regarding you overheating, there are a few more things you might look at. Pull the water hose off the input side of the transmission cooler. I had some overheating problems and it turned out that the passageway through the cooler was about 80% covered with leaves. If that doesnt work, pull the thermostat out and run the boat (temporarily) without it. If the engine stays cold, you know you're getting pleny off supply from the raw water pump. While you have the stat out, throw it in a pot of boiling water to test it or better yet, go ahead and replace it. They're cheap and you might as well do it while you have the housing apart.
If none of this helps. post back with more info and we'll see if we cant diagnose it.
Also, you should never rule out a faulty guage or sending unit. It would kinda suck to replace the whole cooling system just to find out that the engine wasn't overheating and your instrumentation was just lying to you.
Good luck
Cheers,
DKJ
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
