impeller help. 351 pcm
ok so i've let my boat run on a hose for 30 minutes several times and never got hotter than 150. went to lake today and it stayed on 180. what is the normal temp on your boat and what direction does it spen? as in when it is mounted is it clockwise or counter clockwise. o and what is your normal oil pressure?
My boat always stays cooler on the hose, I'd say ur temps are normal. My oil pressure gauge has been acting funny for about a season now and i'm only learning to be a gearhead so no oil press. comment!
I do know that if ur impellor was installed upside down you'd know right away, if it's the one you got with the boat, it wouldn't hurt to replace it...
Lets get some pics of that tower.....
90 Conbrio
