My 22ssv gg is taking on water while moving. After pulling for about 8 min there is around 2.5 gal coming out of the pump.
check your hoses and water pump....have someone run it with the cover off and see if you can spot a leak. If not, you might have a leak in the hull....
also check all your ballast lines and connections.
2007 Moomba Outback
Why Not? Play Hard! Get WET.....
what year is it? have you checked your shaft seal?do you have a heater? are all your hose clamps tight? did you summerize it or someone else? shut off your ballast inlet valve and see if you still get water to eliminate that. Otherwise its prob your shaft seal , or a post engine impeller leak imo
2009 21v Worlds 340 Cat
Doug
was it winterized properly? my buddy's had the freeze plugs blown out he got lucky it didn't effect the motor
we actually had a boat broght into the shop last week. owner complained that the bilge ran constantly when he was on the water and the motor ran hot. turned out the shop that winterized it (has since went out of business) forgot to put one of the drain plugs back in after draining the motor. but i second checking all water line connections, if its tacking on water while in motion thats most lickely the culprit
Thanks for the help. I will check all those things. I replaced the impeller and thermostat this winter so that or the ballest intake may be the source of the leak.
Any weight up front?
Mine takes on water when the bow eye hook goes thru a wave. I have to reseal it.
We removed the middle cushion up front, and while wife drove at idle, I cupped my hands forcing the water around the hook and sure enough, a steady stream would trickle down the floor.
2004 Supra Launch 22 SSV
5.7L Indmar Assault
"One More Hour"
