Boats are made with both proccess. Gel spray is first coat into mold second is shredded chop mixed with catalized resin. This is hand rolled to eliminate any air pockets. There might be several coats of chop applied. Then a layer of woven material is saturated with catalized resin. Various places can have layers of coremate, with is also saturated with resin. All of these items must be hand rolled, or squeeged out. Once hull is skined, the stringers are then applied. The stringers are bedded down with fillers and mat. The stringers are covered with woven material rolled out and bonded to the hull. The floor is applied once the stringers are skinned and preliminary set up is cured, usually 4 to 5 hrs. Once the floor is applied and cured, the hull can be "popped" from the mold. The hull is then placed onto a dolly and pushed into the grinding room, This is where all the foam is injected into the cavities of the hull and rough glass is ground smooth. Next is interior spray of gel in bilge. This process is usually only 24 hrs to 36hrs max. Al
Supra Beast
Custom 496 MPI HO 425 hp
Custom Teak floor
