So I noticed some oil leaking into the bilge the other day. I found root cause of the oil drain plug. For anyone that didn't see my other thread, I put a regular drain plug in after breaking the elbow and hose drain set up. The oil drain plug I got has a plastic washer / gasket. Last night I thought I'd snug it up and when I did it turned quite a bit.
I'm wondering...
Should I have put teflon tape or other thread sealant on?
Should I be using a different sort of washer / gasket?
Thoughts?
