Boat info: 1988 supra mariah. 351 w.
I have a rudder that is very sloppy (not leaking) and is slightly tilted to the port side. Are the rudders suppose to be vertical with no tilt? Its almost like since the rudder is offset from the center of the prop coming out of the boat it is tilted to the center of the prop. Its super hard to turn starbord, easy to turn port. Also, if/when I change out the rudder how do the aftermarket smaller rudders compare to the original larger surface area rudder? Should I try to restore the original? Thanks. My wife lost the camera or i would insert pics.
