I have an 02 launch. Boat has perfect pass wakeboard pro version 6.5. I am running dual batteries. one battery is a marine starting battery the other is a marine deep cycle battery. Both are connected to a perko switch. I have taken the alternator off and had it tested, and all is good. Alternator is stock 70 amps. I am running a 1000 watt amp connected to a 3 farid cap. when the motor is running at low rpms (idle) the perfect pass will cut on and off if the ballast pumps and blower are on. when the boat is running at cruising speed and the radio is turned up and hits perfect pass will cut off. running the heater or tower lights is almost out of the question while running perfect pass as it will once again cut out. I have gone to a local audio shop and they suggest running radio and amp to the same battery. Not sure if a bigger alternator would fix it as the motor never seems to be affected? Any Ideas would be extremly helpful.
