Does anyone know the Max RPM of my boat?
Oh and its a 1988 Supra Mariah. 351W. No mods.
I would like to see how close I am to it at WOT. Trying to see if I am gonna get a new prop.
WOT on a 80's model 351W should be about 4400. My 86 Sunsport with the same motor will only get about 4100 with the standard 13x13 prop - pretty sure she runs out of hp before getting to WOT of 4400. I'm going to try a 13x11.5 and see I pick up a few hundred rpm.
4200 to 4600 on the ol 351 Fords.
Supra Beast
Custom 496 MPI HO 425 hp
Custom Teak floor
Good answer, that's what I hoped you would say. Is your transmission 1:1 ratio? If your turning a 13x13 with 1:1 trans your mph should be real close to your speed (i.e. 2000rpm = roughly 20mph and 3500rp = roughly 35mph, of course this can vary with how the boat is loaded/weighted). This rule of thumb has held true for my Sunsport and my friend's Comp with the same driveline - 351W, no modifications, 13x13 prop and 1:1 transmission. I wonder if your 20 year-old prop is worn in a way that makes it spin easier without as much "bite". That would explain the higher rpm and slower speed, unless of course you have a reduction transmission.
Daniel - I wonder if it has always run up to 4500. You have the same sticker that mine has (or had on the OEM valve cover)
It shouldn't hurt a 351w to spin higher than 4400. I've never heard of 351w rods that couldn't take such a low RPM.
Now, interesting question... When did Supra put 460s in these boats? If my 454 ever blows up I'd enjoy building a 545 stroker for it. I guess all that would be necessary is a bellhousing, coupler, and mounts... Mounts being the tricky part I guess.
I've heard of 440's in early Supra's, but never a BBF. I ran a 460 in an old jet - pretty common & lots of marine parts available. You could probably make something work if you really wanted to...
