Results 1 to 5 of 5
    Houston, Texas
    Default Subwoofer placement for beginners
    I have 2 10" subs to put in the boat. I was thinking of cutting holes on both sides right below the storage shelves. (black circle in the picture)
    I figured I could adjust the sound by packing the inside around them with some type of acoustic insulation. I dug around on the forum and could not find anyone who did the same thing, Most everybody else puts them under the driver's console in a box, but I wanted to leave that open for storage.
    Any suggestions here? Would the subs sound OK?
    2000 Supra Launch 21
    Needs a little TLC
    B.O.A.T.
    Sep 2004
    Hudson, WI
    Unless your subs are designed to run in a free-air environment, they will sound horrible. One good 12" in a proper box would sound much better and you can probably push it far enough forward in under the drivers footwell to be out of the way.
    Plus -- there probably isn't enough room behind there for a sub, anyway.
    Houston, Texas
    tks wotan,
    they do say "designed for free-air installation" I am pretty sure I have the depth in the bulkhead.
    Needs a little TLC
    B.O.A.T.
    May 2006
    Nashville
    I've heard free-airs that sound good. I know a Baja that had 4 of them, and really hit hard. You're going to need some serious subs and a lot of power to get them to the level a box would get you to.
    But if they are done right, they can sound awesome.
    Houston, Texas
    Thanks for the feedback guys.
    I'll probably go with a ported box, they are pretty cheap online. I have a 6 channel amp, the 2 sub channels are 250W rms / 500W max each, same rating as the subwoofers rms 250W/max 500W.
    The more I think about it, I am not thrilled about cutting into the sides of the boat.
    Needs a little TLC
    B.O.A.T.
