I read in the Indmar manual that the 2005 & later Skier's Choice boats are using a different impeller (as opposed to the standard Johnson 812 impeller that I believe all prior Indmar engines required).
In my case I have the Launch 21v and I am planning on switching this out. In addition to the specific impeller, I'm curious about a couple other items..
1. Unlike a direct-drive, these V-Drives seem to be a bear to gain access to the impeller. Is the recommended method to remove the water pump altogether, and change the impeller away from the engine?
2. Has anyone used those new "Run Dry" impellers? I've seen them advertised for a few years now, for example: http://www.globecomposite.com/files/...er_article.pdf but am not sure whether they'd be worth the money because I'm just not sure if it's possible to do what they claim based on impellers I've witnessed that have run dry!
Thank you in advance!
RKM
