I am not with my boat right now but in the process of buyimg a new engine, what is the propeller rotation of my 1991 supra sunsport. 351 windsor. Pcm powerslot 1.23x1 transmission?
I want to make sure as i search for a different 351
Edge
Edge
IT's just a boat - You need to love it!
Caress Me down - 1991 Supra Sunsport
1:23 to 1 pcm transmission is a right hand rotation of the prop
Hey Edge,
Maybe this can help. Your firing order should be on the engine tag.
http://www.planetnautique.com/vb3/sh...0-firing-order
Ok, you have a PCM tansmission with a RH rotation output, but it has a LH rotation input. Your engine is a LH rotation viewed from the flywheel.
Al
Supra Beast
Custom 496 MPI HO 425 hp
Custom Teak floor
So if its right hand rotation of the prop it would be left hand or a standard rotation engine, on a 1.23x1 pcm
my understanding is that the rotation of the 1:23 to 1 is the reverse of the engine rotation.
If Engine rotation is left then tranny is right
If Engine rotation is right then tranny is left.
Any doubts check with ski dim - can alway answer your questions.
