Results 1 to 7 of 7
    Jul 2011
    Default Whining Noise in Reverse
    Hi. I'm new to the forum. I currently own a '86 Sunsport Skier and am looking at a '02 Launch direct drive. When in reverse, the Launch makes a loud whining type noise. Is that normal or a sign of a problem pending? My '86 doesn't do that. Thanks!
    May 2005
    Portland, OR
    I would not think it is normal. I would have someone look at it.
    Sep 2008
    Parkersburg, WV
    Are you getting rid of your Sunsport?
    Clint
    www.waketheworldwv.com
    May 2006
    Nashville
    If it's really loud, no, it's not supposed to do that. But if it's a low volume whine, all my Supra's have done that.
    I know mine whined REALLY loud when it was due for a Transmission fluid change. Changed the fluid and it was back to a nice quiet low volume whine in reverse, like it's supposed to. My guess is, needs a fluid change.
    May 2009
    syracuse Indiana
    The Borg Warner Velvet drives, like your 86 has are exteamly durable and quiet, The PCM transmissions have a light whine in reverse. It is too bad Borg Warner quite making trannys for boats, they are still the best around. Al
    Supra Beast
    Custom 496 MPI HO 425 hp
    Custom Teak floor
    Sep 2009
    Spokane, WA
    Mine also has a slight whine when in reverse. I looked into this as well when I first got it. All the research I did said it was normal.
    2008 Sunsport 22 V
    Aug 2010
    Houston, Texas
    Mine has a low whine too in reverse always assumed it was normal.
    2000 Supra Launch 21
    Needs a little TLC
    B.O.A.T.
