Results 1 to 10 of 19
    May 2010
    Dixon, IL and Columbia, MO
    Default Old Supra Gauges to LED
    Anybody with an older Supra (or new I suppose) swap out bulbs in the dash gauges for LED's? I'm thinking about doing blue to match the blue LED accents I just installed, just wondering if it's possible.
    Jun 2010
    Ontario, Canada
    I have not done it, but you can get direct replacement 12V led bulbs for sure. They are called #194 bulbs iirc.
    May 2010
    Thanks for the heads up, I might tear into mine if I have time tonight to see what kind of room there is in there.
    Jun 2010
    Ontario, Canada
    I just did some quick Google searches and the options are vast, there's a ton of choices at various price levels.
    Make sure to update this thread if you get some.
    Quote Originally Posted by Ptownkid View Post
    ive done it.. works good.. I did a bright white because the blue was dim
    Jun 2010
    Ontario, Canada
    You can get all sorts of different levels of brightness though...
    Apr 2002
    Austin
    red is more of a traditional color gauges...might contrast your blue nicely too
    Jul 2008
    Whidbey Island Washington
    Your replacement incandescent lamps are probably also availible in blue. Check with your local NAPA store.
    Rick Ludtke
    1990 Supra Pirata
    1987 Supra Comp TS6M
    May 2010
    Red wouldn't be bad.. hmmmm
    I think I would like to go with LED for sure though for the simple reasons of longer life, won't ever burn out probably, and they use far less energy... plus I was planning on doing an LED order for some other things anyway
    May 2010
    dshaff, you wouldn't happen to have a picture of the blue ones you tried would you? Picture of your current set up?
    I don't know if I'll go to the trouble if blue isn't going to be bright enough... but, my gauges really aren't that bright to begin with
