Originally Posted by
Blackntan90
I did the brake lines/hoses and master pretty early on as well- it is scary as hell getting pushed through a red light in a half ton truck because your trailer just blew out a rusted brake line!! When I replaced the line going through the frame from the tounge back to the front axle, I found that is where it had rusted through. So I painted the lines(old ones were not!) and put a couple of short lengths of hose over it to prevent chafe inside the frame where you cannot secure it in any way(other than spray foam!) It is a crappy job, but if you have the right tools(double flare tool,line wrench), it is well worth it!
My lines are painted and don't show any sign of rust... but.... How did you run the new line into the frame? Mine looks like it was put in before the coupler was welded on.
