Results 1 to 7 of 7
    Oct 2009
    Macon, Ga
    Default Prop and weight setup 2003 ssv
    Last season i had no issues surfing behind our 2003 SSV. over the winter we replaced the stock prop with a 1433. The boat has great pull out of the hole, but now i cant get the surf wake clean and enough push. here is my setup, any advice:
    2003 SSV
    1100lb in the center locker (filled to 900 lbs)
    440 lbs rear port side locker
    400 lbs on top of rear port side locker
    wake plate - ????
    ACME 1433 prop
    10.5 MPH
    Does this seam like a surfable (not a real word) setup? Has anyone else had their prop effect their surf wake?
    I have also heard of filling the opposite side locker slightly? Anyone had luck there?
    2003 SSV, Tsunami fill pump upgrade, 2000lbs ballast, ACME 1433, stereo upgrade in process.
    May 2010
    Louisville, TN
    I have an 03' SSV and I am stilll learning on the set-up as well.
    Last time out I was able to toss the rope, but there wasn't much push to the wake, and the pocket was still pretty small.
    Front:
    500 lb in locker
    650 lb in walkway front pushed to the surf side
    Rear:
    300 lb in starboard locker (I'm goofy foot)
    650 lb on starboard sunpad and rear seat
    no weight in port side locker.
    4 people on board
    Speed: 10.3mph and the plate was all the way up (0%)
    The nose was a bit too heavy, but it was surfable.
    Oct 2009
    Macon, Ga
    it seems like we have similar setups, maybe this weekend i can try to fill the opposite side and see what happens.
    May 2010
    Louisville, TN
    Still learning. This past weekend I went with the same set-up as before, but I filled the port side rear locker (300lbs) and sped up to 10.7mph. I think the off side weight was a mistake. I am still not getting much push. I am a bigger guy (210-215lbs), but I am also riding a 5'6" board. Any advise out there? Are the earlier V-drives just not that good for surfing? I love the wakeboarding wake, there are tons of ways to adjust it, but it just doesn't seem to respond to what I am trying for surfing. HELP!
    May 2009
    Quote Originally Posted by Patrick56 View Post
    Patrick, with that setup, here's what I would do:
    Front - 500 lb in locker, 300 lb from starboard locker in center walkway
    Rear - 650 lb from front walkway in rear locker, 650 lb on starboard sunpad/rear seat
    no weight in port locker
    wakeplate 50%, raise as needed to clean up wave
    speed 10.5-11.2 broad range, I know, but it's also one of those things the driver has to play with
    If you can't move the 650 lb bag from the front to the rear locker, then I'd at least move that bag to the center walkway and sink the belly of the boat instead of the bow. Personally, I've found, on my 05' 22ssv, that weight too far forward is counter-productive. Also, I've never had any success with weighting the non surf side.
    2005 Supra Launch 22ssv - yellow/black
    May 2010
    Louisville, TN
    So basically you are saying more weight in the back corner and use the wakeplate to hold the nose down a bit?
    Unfortunately I am still playing with old style and new style bags, so I am limited on how much I can move things around. I will give it another shot. Hopefully on Saturday.
    Thanks for the advice.
    Also, I am running an ACME 1939 prop (14" Dia x 15.5 Pitch) It has helped alot with slow speed control and hole shot. Not sure if anyone has experience with this prop. I think it was OEM on Wakesetters for awhile.
    May 2009
    Quote Originally Posted by astinwes View Post
    I have had my wave dialed in for a few seasons, then this season replaced the prop with an ACME 1235 (14.5 x 14.25). Wave turned to garbage, and I've spent all season getting it back in shape.
    I've moved weight around a bit, and played with speed and wakeplate position, but just couldn't get rid of the prop wash. I read a thread on wakeworld ( http://www.wakeworld.com/forum/showthread.php?t=785959 ) and copied the wave flap that Duffy came up with. It seems to have made a nice difference
    I run much more rear weight than you. Do you have any additional bags laying around?
    Can you move the stock 400 bag from the starboard locker to the port side seat/sunpad while surfing?
    Any pictures of last years' wave vs. this years?
