Replying to Topic 'How do you use oil drain hose?'
The engine will likely need to be warm for the oil to come out at any apreciable rate. I tried to drain mine once when it was cold and it took a couple hours. Also, you might remove/loosen the oil filler cap to let air down into the crankcase. That might speed the flow a little. If thats not the problem, then i'm stumped. I gave up on the hose and started using a Topsider vacuum pump to suck the oil out through the dipstick tube.
Cheers,
DKJ
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
