Results 1 to 9 of 9
    Sep 2011
    Default I need a shaft and prop for a 86 comp ts6m
    Does anyone have a prop shaft or output shaft and a 3 blade 13 x 13 or 3 blade 14x14 left hand prop for a 86 comp ts6m? Or does anyone know where I can find one?
    Nov 2008
    Walkersville,MD
    jb, skidim(discount inboard marine) is my only guess for new parts(skidim.com)
    Dec 2009
    McKinney Texas
    I have a prop for sale.
    2004 Supra Launch SS
    May 2009
    Back to Dallas!
    You can take your measurements to a local machine shop (someone on here can give them to you, I cant remember) Its a 1"x??x?? and they can make for you one cheap. Last time I blew mine out (yes, alchohol was involved-DONT JUDGE ME!!) I had mine made for $125. Very easy to make on a lathe machine. Also, If you hit something make sure you didnt lay your strut over a bit. Jet
    89' Comp rebuild thread:
    89' Comp Mod's and fun pic's:
    May 2010
    Carlsbad, NM
    Default Prop/shaft
    I have a couple of 14x14 LH props and 42" shafts I am having turned right now that I might be willing to let one set go. They are off of my '89' Supra Conbrio, which is the open bow version and same setup you have. I'll probably need to sell one set since I need to find a strut. I noticed mine is a little bit off.
    May 2010
    Carlsbad, NM
    I was wrong on the props, mine are the RH 14x14 since I have the 1.23:1 powerplus trans. Sorry about that. The shafts should still be the same, you might measure and see. These are great.
    Sep 2011
    How much do you want for the shaft?
    Jim
    I have a acme CNC prop that is 13x14 LH 1.125 bore but i have the spacer to fit a 1" shaft i had this as a spare for my rider and used it once or twice to see how it ran and it was super smooth. I sold that boat and its too small a prop for my new lsv 247 it looks like new and sells new for $400-$500 i will let it go for $250
    Ken
    May 2010
    Carlsbad, NM
    $200 and includes the shaft coupler that was refaced also. Sorry I didn't get back sooner.
    James
