Do you guys know how to change the timer on an 09' Supra? I know how to do it with the ones that have VISION, but I heard there is some way to reprogram the timers so they stay on longer. Anyone?
Found this. Maybe it helps. If not wakemakers sells the timer so they should have destructions.
http://www.mastercraft.com/teamtalk/...ad.php?t=41503
Brad
2011 Supra 21V
Big Bay Lake, Mississippi / Baton Rouge, LA
Brad
2011 Supra 21V
Oh boy... this looks like a lot of work. Thanks Brad. I will check it out.
Not as easy as Vision setup for sure!
Brad
2011 Supra 21V
So how do you change the timer on the VISION system? I just bought Trevor Hansen's 2010 Launch 24V and it looks like the rear ballast are not factory, but I don't know what size they are? I do know that the factory timing does not fill them and I'd like to reset it so it does. Can you point me to the right thread or tell me how? I could not find anyting using Search bar.. thanks
It is pretty easy.... Can't remember specifically, but go into VISION and go into UTILITIES and there is an option for Ballast Configuration. You then select how many minutes you want it to fill or empty.... Depending on how big the bags are you will set the times. Stock bags are about 4 minutes. You can play with the time and make sure it fills for you.
Great, thanks for the info. I didn't think it would be that easy judging by those other instructions on this thread..
- 2010 LAUNCH 24V -
*3,450lbs Ballast (Fly High) *Indmar 340hp *Progressive Tower w/ Swivel Racks *Z5 Cargo *Transom Remote *Pkg F: Tower Speakers, 2 Amps, Light Bar *Dual Battery *Zero Off *Tonneau Covers
